Discussion topic: No internet connection
This message was authored by: RoslynPryce
I have no internet whatsoever
Re: No internet connection
@RoslynPryce
If you haven’t done it yet you can use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour or so later).
wfh: Sky broadband being discussed here is a domestic service and whilst it's fine for those customers working from home to use it, they won’t receive additional or quicker support.
Avatar for RoslynPryce
Hi Danielle
there were issues last night with open reach. I spoke with sky this morning and they said it's an ongoing issue hopefully sorted for Monday but they will compensate the days I'm without. Thank god I got backup
@RoslynPryce
You may not be eligible for auto compensation if fixed on Monday,
Sky usually quote 2 WORKING DAYS as a potential fix time as this is the service level agreement in the UK between ISPs and Openreach for fixing a fault. Openreach claim to be successful within that timeframe in up to 85% of cases.
This link explains the Ofcom agreed auto compensation scheme which Sky operates for when there is a TOTAL loss of Sky Broadband or Sky Talk for UK customers.
https://www.sky.com/help/articles/auto-compensation
If you have a total loss of service and it isn’t fixed after two full WORKING days from when Sky are notified of the fault, you will become eligible for it.
From Ofcom’s website:~
If your broadband or landline service stops working, you will have to report the fault to your provider. If the service is not fixed after two full working days, you would not need to ask for compensation or contact your provider again, as your provider has systems in place that mean you will start receiving compensation automatically if the repair takes too long.
This auto compensation is applied 30 days after the fault has been repaired and will come in the form of a credit appearing on your Sky account (from 01/04/25 the new rates are £9.98 per day)
▫️There is no equivalent scheme in place for customers in the Republic of Ireland.
▫️There is no automatic compensation for TV services affected by a broadband problem.
▫️I’m not aware of City Fibre being part of this scheme.
▫️Sky broadband being discussed here is a domestic service therefore whilst it's fine for customers who work from home to use it for that purpose they won't receive additional or quicker support.
