This discussion topic has been answered Discussion topic: No internet connection
Message posted on 20 Oct 2025 10:53 AM
Can't watch any tv
cannot connect any device
i work from home via Zoom
Help?!
I have done all the usual checks and followed all steps.
this has happened for the 3rd time now - unfortunately haven't made note of when.
can I speak to someone please or organise an engineer visit?
many thanks
Sam
Message posted on 20 Oct 2025 10:55 AM
@SJXC
You aren’t communicating with Sky by posting on here. This is a customer ➡️ customer discussion forum where we try to help other Sky customers.
You can use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour or so later).
wfh: Remember Sky broadband being discussed here is a domestic service and whilst it's fine for those customers working from home to use it, they won’t receive additional or quicker support.
@SJXC
