Discussion topic: No internet connection
This message was authored by: LindaHarris
No internet again this afternoon. None for last two days
it came back this morning but very slow.
Re: No internet connection
@LindaHarris
Use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour or so later).
Avatar for LindaHarris
Level 0 icon
I've done all that. Is there a  chat function?
@LindaHarris Yes there is, via the contact us option if it indeed shows up for you!
