Discussion topic: No internet connection
This message was authored by: Filiq-
No internet
did all the tests
light not on the router
Re: No internet connection
@Filiq-
Use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour later).
