Discussion topic: No internet connection
This message was authored by: Simon308
Hi,
all lights are on on our Sky router and on the Openreach access box but we have no internet at all.
please help
kind regards
simon
Re: No internet connection
@Simon308
If you are having broadband problems use this link to check to see if there are any issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour later).
