Discussion topic: No internet connection
This message was authored by: Meachin+House
My WiFi is working and my devices will connect to the router however every device in the house says there is no internet access. I have run the checks on the mysky app and it is saying there is no issue yet there must be as there is no internet anywhere in the house
Re: No internet connection
@Meachin+House
If your broadband isn’t working use this link to check to see if there are any problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update).
