1
This discussion topic has been answered Discussion topic: No internet connection
This message was authored by: Marion33
Tried to connect but still no internet
Re: No internet connection
@Marion33
What do you mean by "still no internet "?
If your broadband isn’t working use this link to check to see if there are any problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update).
@Marion33
