2
This discussion topic has been answered Discussion topic: No internet connection
This message was authored by: EKCP
Re: No internet connection
@EKCP
When there are issues between midnight and 7am it's quite possibly going to be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep.
If it hasn't returned by 0700 use this link to check to see if there are any
broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (Remember it doesn’t necessarily disclose a problem instantly and it takes a little while to update).
@EKCP
Avatar for EKCP
Thank you so much for your help. Much appreciated
