Discussion topic: No internet connection
This message was authored by: JamieC124
daily intermittent faults with router. Line tests on your end saying no fault. Reset router multiple times and performed checks with openreach equipment. Look to have this resolved asap before I terminate contract
Re: No internet connection
@JamieC124
No point in threatening to cancel on here. In case you’re not aware you aren’t contacting Sky Customer Services on here. This is a customer led discussion forum where Sky customers are available to try to help other customers.
When there are issues between midnight and 7am it's quite possibly going to be essential overnight maintenance taking place which is carried out then to minimise disruption.
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (Remember it doesn’t necessarily disclose a problem instantly and it takes a little while to update).
