Discussion topic: No internet connection
Message posted on 26 Aug 2025 07:18 PM
Connected to the router but no internet connection, comes and goes every 10 minutes or so
Message posted on 26 Aug 2025 07:37 PM
Re: No internet connection
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (Remember it doesn’t necessarily disclose a problem instantly and it takes a little while to update).
