Discussion topic: No internet connection
This message was authored by: Tash20
No signal no tv
Re: No internet connection
@Tash20
Your 4 other posts/threads have been removed.
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (Remember it doesn’t necessarily disclose a problem instantly and it takes a little while to update).
