Discussion topic: No internet connection
Message posted on 24 Jun 2025 08:14 PM
I have no internet connection from my hub. No phones or tvs connected. I need help
asap as I work from
home
Message posted on 24 Jun 2025 08:29 PM
Re: No internet connection
@Danielle243 If you happen to have a mobile data signal then you could try the service checker to see if sky are aware of any particular area wide faults, but they do not always know those.
Try running the line test here to see if any faults are found:
