Discussion topic: No internet connection
This message was authored by: Jaleighbird
I've tried pushing all wires back into the devise and turning the sockets off at the wall but the broadband isn't working
Re: No internet connection
@Jaleighbird See the about below.
@Jaleighbird
Do they look like they've come out?
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
Its worth adding that for customers working from home remember that Sky Broadband is a domestic service so you won’t receive any quicker or extra support.
