Discussion topic: No internet connection
This message was authored by: SebYVal
There is no Internet connection, I can see the red faulty light on one of the devices
Re: No internet connection
@SebYVal
At that time of night it could be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep.
If it's still down after 0700 use this link to check to see if there are any broadband problems or outages nearby. Note: the service checker sends routine tests to the hub and won’t necessarily register any issue until the hub fails to respond.
