Discussion topic: No internet connection
This message was authored by: DawnThommo
Right light on openreach box 'LOS' and no internet
Re: No internet connection
@DawnThommo
For a ‘no broadband’ issue, if you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
Avatar for DawnThommo
Level 0 icon
The sky broadband checker says no issue but red light on breach box and no internet connection
@DawnThommo Red light on the LOS is you have no fibre optic signal between home and the exchange for whatever reason. With that condition then it is a call to sky, they may know off a specific reason but you are not getting internet until it goes out....
