Discussion topic: No internet connection
This message was authored by: Leahgardiner
My internet isn't workinh
Re: No internet connection
@Leahgardiner
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
▪️I AM NOT A SKY EMPLOYEE ▪️
