Discussion topic: No internet connection
Message posted on 15 Apr 2025 07:06 AM
Noticed broadband went down yesterday. Tried everything to get it back on, nothing works. Must be a huge outage somewhere even though Sky havent reported it. I tried to reset this morning (05:45am 15/04/2025) still not working.
Message posted on 15 Apr 2025 07:33 AM
Re: No internet connection
This should determine if there's an identified fault affecting multiple households.
Message posted on 15 Apr 2025 07:34 AM
I would call sky and report this issue to them they may not be aware of it
