Discussion topic: No internet connection
Message posted on 18 Mar 2025 09:28 PM
My internet service went off for more than an hour now. I use internet checker in your app and it shows good service that nothing is wrong yet there is no service. This is limiting me. This is not the first time it happened.
Message posted on 18 Mar 2025 09:46 PM
Re: No internet connection
I have exactly the same issues.
Checker says all is well but my ONT is red showing LOS.
Message posted on 18 Mar 2025 09:49 PM
It's not nice at all. They need to do something about it.
Exactly the same for me . Service checker saying everything fine but internet definitely not working for me.
Message posted on 18 Mar 2025 09:54 PM
Same here, it's dropped out saying everything is fine, but clearly not. I live in the Southampton area UK.
Message posted on 18 Mar 2025 09:57 PM
We are in Southampton too and having problems. All checks say everything is fine.
Message posted on 18 Mar 2025 09:58 PM
Message posted on 18 Mar 2025 10:02 PM
Then it's a nationwide issue. Sky needs to act on this because we're paying heavily for their services.
Message posted on 18 Mar 2025 10:03 PM
This is not encouraging at all
Message posted on 18 Mar 2025 10:36 PM
I'm in Southampton and mine has been off for more than an hour now!
Message posted on 18 Mar 2025 10:39 PM
NO INTERNET
Internet stopped working over an hour ago but says no problems ???
Southampton area
Message posted on 18 Mar 2025 10:46 PM
I am in Southampton and my light is orange. Has been for ages now!
Message posted on 19 Mar 2025 02:37 AM
My connection was reconnected at 2:10am, hopefully everyone else is now reconnected.
Message posted on 19 Mar 2025 05:10 AM - last edited: 19 Mar 2025 05:12 AM
Re: NO INTERNET
