Discussion topic: No internet connection
Message posted on 02 Mar 2025 08:12 PM
Message posted on 02 Mar 2025 08:18 PM
Re: No internet connection
@Ajs+21
(For any customers working from home remember that Sky Broadband is a domestic service so you don’t receive any extra or quicker support).
