Discussion topic: No internet connection
This message was authored by: Kelgib40
No connection at home was on and off yesterday also
Re: No internet connection
@Kelgib40
If you’re still having problems you may need to call Sky to report it (dial 150 free from your Sky Talk landline).
In addition~
▪️This link providers information about the coloured lights on the various hubs
▪️ For any customers working from home remember that Sky Broadband is a domestic service so you don’t receive any extra or quicker support.
