Discussion topic: No internet connection
This message was authored by: Jerry93
No internet connection for almost a week
Re: No internet connection
@Jerry93
The lines may be busier than usual due to the damage and disruption caused by Storms Éowyn and Herminia which will also impact any Openreach visit.
