Discussion topic: No internet connection
Message posted on 03 Sep 2024 08:58 PM
Message posted on 04 Sep 2024 07:49 AM
Message posted on 04 Sep 2024 09:17 AM
Re: No internet connection
@EmmaScanlan Can you please run the service checker, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
After the service checker completes and if it comes back green all good can you click on broadband to run an updated test please. If you get amber or red please follow the on screen instructions.
Message posted on 04 Sep 2024 09:46 AM
I've done that and it says there is no fault but there is
Message posted on 04 Sep 2024 09:47 AM
@EmmaScanlan Are the lights on the router a different colour?
