Discussion topic: No internet connection on broadband
Message posted on 27 Jan 2026 05:02 PM
Wifi commected but no internet
Orange light blink in internet and voice light turned off
Message posted on 27 Jan 2026 05:37 PM
Re: No internet connection on broadband
See further down about the hub lights @Aswin12
With any broadband issue the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
