2
This discussion topic has been answered Discussion topic: No internet connection in IP22
This message was authored by: FRM
No internet connection in IP22.
Did reset the hub twice. Still no connection.
Re: No internet connection in IP22
@FRM
Even if you’ve already tried it use this link to check if there are any broadband issues locally that may identify a known fault, perhaps affecting multiple households ~
Its always worth rechecking it as the Service Checker doesn’t necessarily disclose a problem immediately and there is up to an hours delay before it picks up a lost connection so perhaps try it again later.
@FRM   First thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
@FRM
