Discussion topic: No internet connection again 🤬
Message posted on 24 Jun 2026 07:32 PM
The internet connection has been going on and off for the past few days. I have followed instructions on the box but nothing is working
Re: No internet connection again 🤬
@Wendy154
Use this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
