Discussion topic: No internet connection. Modem red
Message posted on 03 Aug 2026 05:45 PM
We currently have no broadband connection. The modem is red. I think there may be works going on in the area which could be effecting this. Please can you check and update me ASAP as I work from home as a remote worker.
thank you
Message posted on 03 Aug 2026 06:12 PM
Re: No internet connection. Modem red
@Andrew404 you are not talking to Sky by posting in this firum. However you can checck yourself by running the Service check in the My Sky app which will tell you if Sky are aware of an issuexaffecting uour line. The checker does take up to an hour to pick up a dropped line but once it does it can take you through somecsteps before booking an dngineer.
You need to be aware thst you are buying a domestic connection and the fact you use thst for work does not give you any priority. Domestic faults should be fixed within 2 full working days or comprnsation will be paid
