Discussion topic: No internet at home
This message was authored by: louie2006
No internet at home
We had no internet last week for 3 days it then came back on and it's now gone off yesterday again.
Re: No internet at home
@louie2006
The first thing to try (even if you’ve already tried it) is to use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
