Discussion topic: No internet again
This message was authored by: Marielygo
No internet again
No internet no t v this is happening every week now sometimes 2 /3 times a week what am I paying for
Re: No internet again
@Marielygo
When you have a broadband issue the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
▪️I AM NOT A SKY EMPLOYEE ▪️
This message was authored by: Sky1011
@Marielygo this sounds super frustrating.
I recommend you give Sky a call - this is just a customer forum where other customers give best guess ideas or copy and paste replies of router light meanings like you've already seen. You're not going to get support here. Keep a note of how often you're getting the disconnects and for how long each time. If you call Sky directly, make sure to open a complaint with them. Say you're looking for compensation from the outages. They should be able to check if there's an issue with the line too.
Also take a look at what other providers are available in your area, and don't be afraid to switch.
@Marielygo
This link explains the Ofcom agreed auto compensation scheme which Sky operates for when there is a TOTAL loss of Sky Broadband or Sky Talk for UK customers.
https://www.sky.com/help/articles/auto-compensation
If you have a total loss of service and it isn’t fixed after two full WORKING days from when Sky are notified of the fault, you will become eligible for it.
From Ofcom’s website:~
If your broadband or landline service stops working, you will have to report the fault to your provider. If the service is not fixed after two full working days, you would not need to ask for compensation or contact your provider again, as your provider has systems in place that mean you will start receiving compensation automatically if the repair takes too long.
This auto compensation is applied 30 days after the fault has been repaired and will come in the form of a credit appearing on your Sky account (from April 2026 the rate has increased to £10.34 for every complete day).
There is no automatic compensation for TV services affected by a broadband problem.
