Discussion topic: No internet again
This message was authored by: Sophie79
No internet again
This is the 4th time it's happened to me this week. The power and WiFi lights are both green, the voice light is orange and the internet light is off but my service checker is saying there is no issue!!
Re: No internet again
@Sophie79 And as the light indicates, there is a broadband connection issue with your line,hub,exchange, sky! so could be anything.
Service checker is not an instant tells you there is a problem, that takes a little time to show what is going on!
This message was authored by: Arunpatel
No internet  and broadband
@Arunpatel
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
