Discussion topic: No internet again
This message was authored by: Kp41
No internet again
My television and Alexa keeps loosing WiFi connection on a daily basis. Sometimes for a few minutes sometimes longer. Most of the time the sky app tells me everything is ok when it clearly is not. Continuously having amber flashing lights on the hub. We have had this a year now and very poor compared to virgin media and more expensive
Re: No internet again
@Kp41
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
