Discussion topic: No interest
This message was authored by: Unhappy221
No interest
No Internet since the early hours, the open reach white box has a solid red light on the PON , I've followed the steps a number of times & nothing is working ,at the point of leaving SKY as it's problem after problem with them, I'm paying for a service that doesn't work,I can't also use other items because of this & trying to get help from them is like hitting your head against a wall
Re: No interest
@Unhappy221
For broadband issues the first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
This should identify if there's a known fault, perhaps affecting multiple households.
