Discussion topic: No inernet connection
This message was authored by: Eszter
I lost the internet connection in my house wifi is nit working.
This message was authored by: Tash110uk
Re: No inernet connection
Same issue here in plymouth
@Eszter @Tash110uk
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
If you’re still having problems you may need to call Sky to report it. The easiest way is to dial 150 free from your Sky Talk landline if it’s still working.
For customers working from home please remember that Sky Broadband is a domestic service so you won’t receive any quicker or extra support.
