Discussion topic: No inernet connection
This message was authored by: Kellyann4
It says connected to broadband router but no actual connection to the internet!
Re: No inernet connection
@Kellyann4
In addition~
▪️This link providers information about the coloured lights on the various hubs
▪️ For any customers working from home remember that Sky Broadband is a domestic service so you don’t receive any extra or quicker support.
