Discussion topic: No ertnet condction through booster
This message was authored by: Camp1
When computer is plugged into the booster we have no Internet.  We have had this plugged in for .onthes no problem. We had a power cut now no connection
Re: No ertnet condction through booster
@Camp1 You need to see if the PC has an Ethernet connection with the Booster, if it does then you have a booster issue with that to the Hub, if not you need to sort out the PC first then go on from that point.
