Discussion topic: No emails
This message was authored by: Virginia2411
Message posted on 23 Mar 2026 12:53 PM
No emails
I haven't received any emails since you installed broadband. Also the broadband signal is weak
Find out more
Message posted on 23 Mar 2026 01:22 PM
Re: No emails
Who is your emails with, is it Sky ?
For the weak signal try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will supply up to 3 pods as you can read about here:
Select "No, I still need help" at the bottom on the above link.
