Discussion topic: No connection
Message posted on 23 Sep 2026 11:06 AM
No connection
I have amber lights for both Internet and voice. I'm going round in circles trying to fix it (service checker says no issues) or speak to a human! Any advice appreciated.
Message posted on 23 Sep 2026 11:30 AM
Re: No connection
@R12345
If you are new to the forum then welcome to the Community, which is predominantly made up of Sky customers helping other Sky customers. You aren’t talking to Sky by posting here.
Start by using this link to check if there are any broadband issues locally that may identify a known fault which could be affecting multiple households ~
(this won’t necessarily identify a fault that just affects your address).
If you’re still having problems you may need to report it to Sky. The easiest way is to dial 150 free from your Sky Talk landline (if it’s still working).
🔸Various hub lights; This link provides information about the coloured lights you may see on the various hubs
🔸Red light on ONT?; See this link ~
🔸Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky allow customers working from home to use it, they won’t receive additional or quicker support.
Message posted on 23 Sep 2026 11:35 AM
Re: No connection
Thanks. I don’t have Sky Talk - what is an alternative phone number?
Message posted on 23 Sep 2026 11:43 AM
Re: No connection
You do actually have a Sky Talk landline as it's bundled with your broadband package but you have chosen not to connect an actual handset which is fine and entirely your choice.
In the future you can plug in a cheap handset when you need to call Sky (dialling 150 free) if the Sky Talk side of things are working..
Call Customer Services by dialling 150 (free) from a Sky mobile. The forum doesn't allow the display of other numbers but official numbers to Sky from the UK are 03 numbers which are usually inclusive from non Sky phones.
All calls will start automated (aka 'the bot') which may offer you the online help route or try to send you here to the forum. Stay on the line as long as possible and sometimes saying nothing when asked the reason for the call helps being put in the queue for an agent.
