Discussion topic: No connection
This message was authored by: Chloe3456
No connection
Been with sky for years haven't had a problem but last night around 930 internet has dropped tried a million ways to connect but still carnt get it to connect  tried everything  plz help
Re: No connection
@Chloe3456
Start by using this link to check if there are any broadband issues locally that may identify a known fault which could be affecting multiple households ~
(this won’t necessarily identify a fault just affecting your address).
🔸Various hub lights; This link provides information about the coloured lights you may see on the various hubs
🔸Red light on ONT?; See this link ~
🔸Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky allow customers working from home to use it, they won’t receive additional or quicker support.
