Discussion topic: No connection
This message was authored by: Nix1410
No connection
Had no broadband for most of today now the TV isn't working as its saying can't connect to Internet
This message was authored by: MartinCayrne
Re: No connection
I'm the same. Sky are in denial that there's a wider issue.
I've got an Openreach engineer booked for tomorrow morning.
Re: No connection
@Nix1410
Start by using this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
If you’re still having problems you may need to report it to Sky. The easiest way is to dial 150 free from your Sky Talk landline (if it’s still working).
🔸Various hub lights; This link provides information about the coloured lights you may see on the various hubs
🔸Red light on ONT?; See this link ~
🔸Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky allow customers working from home to use it, they won’t receive additional or quicker support.
