Discussion topic: No connection
Message posted on 03 Jul 2026 07:10 PM
No connection
My internet connection has gone and it won't reconnect
Message posted on 03 Jul 2026 07:26 PM
Re: No connection
@Laura491
Use this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
