Discussion topic: No connection
This message was authored by: Chezh
No connection
I have no Wi-Fi, broadband or internet connection. Everything is down. I've followed all the advice given on the chat. I keep getting cut off and I have to go back to explaining everything from the beginning. It says there is no problem in my area. When I go to perform a test on my connections it says 'sorry our tests are currently unavailable'
I'm not getting anywhere.
Re: No connection
@Chezh
The first thing to do (even if you’ve already tried it), is use this link again to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
