Discussion topic: No connection
This message was authored by: MWilliams__
No connection
WiFi isn't working
Re: No connection
@MWilliams__
If your ONT shows a red light then have a read of this:
If nothing there helps then the first thing to check is this link to see if there are any outages in your area, it can be a bit slow at picking up issues so if nothing shows perhaps try it again later:
If there isn't try running the line test here:
If this is of no help give Sky a call to report it to them.
