Discussion topic: No connection
Message posted on 04 Jan 2026 01:19 AM
No connection
The broadband has been off for the last 30 minutes
Message posted on 04 Jan 2026 02:22 AM
Re: No connection
Same. The service checker is saying everything is fine but the connection has dropped.
Message posted on 04 Jan 2026 02:59 AM
Re: No connection
It may not be relevant at a weekend but any broadband issues between midnight and 7am could be essential overnight maintenance taking place which is carried out then to minimise disruption. There’s no pre-warning of this. See this pinned post at the top of the Broadband board from Sky which could be relevant any night this happens…
https://helpforum.sky.com/t5/Broadband/Important-Notice-Scheduled-Broadband-Maintenance/td-p/5151847...
If you have an ONT box displaying a red light, see this further advice…
Hopefully it’s back up and running before 7am. If it’s not the first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
This should identify if there's a known fault, perhaps affecting multiple households.
