Discussion topic: No connection
This message was authored by: Angey
No connection
I am not getting no connection from my Wi-Fi box
Re: No connection
@Angey
You mean your hub. Wi-Fi and broadband are different. Wi-Fi is the wireless connection between your hub and your devices. Broadband is the internet connection provided by your ISP (Sky).
The first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
