Discussion topic: No connection
This message was authored by: Chris9871
No connection
Service checker is saying everything looks fine. All green lights are on the router everything connected and set up properly but we cannot connect to the WiFi. I paid my overdue bill last night and normally it's automatically comes on straight after??
Re: No connection
@Chris9871
As well as paying the bill have you also setup your payment method again , if so try running the line test here to see if any faults are found:
If this is of no help give Sky a call to report it to them.
Avatar for Chris9871
Re: No connection
Hi I've tried all this and still cannot connect
is there anybody I can sctuallly speak to instead of getting referred back to service tracker everytime
im running out of data and need the WiFi back up and running asap
Re: No connection
Hi @Chris9871
You can try calling Sky on the 03 number listed at the bottom of https://www.sky.com/help under the 'Need more help?' banner
I am NOT a Sky Employee
