Discussion topic: No connection
This message was authored by: JS39
No connection
Hi.
Ive been having problems recently with connection and the light has been green, it takes 10-15 mins to gain connection again. Today after i came back from work, I couldn't get any connection again and now it's flashing orange (which I know is no connection).
Ive pulled leads out and restarted it and still nothing. Is it a Hub fault?
Re: No connection
@JS39
Try running the line test here to see if any faults are found:
If this is of no help give Sky a call to report it to them.
