Discussion topic: No connection
This message was authored by: Donz412
No connection
I can't get connected to WiFi, but it's saying on app that all is good
Re: No connection
@Donz412
Wi-Fi is basically the connection between devices and your hub. Broadband is the actual internet connection provided by the ISP (in this case Sky).
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
Its worth adding that for customers working from home remember that Sky Broadband is a domestic service so you won’t receive any quicker or extra support.
