Discussion topic: No connection
This message was authored by: Seb1231
No connection
No internet
Re: No connection
@Seb1231
For a ‘no broadband’ issue, if you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
Re: No connection
@Seb1231   First thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
