Discussion topic: No connection
Message posted on 12 May 2025 09:06 AM
No connection
Message posted on 12 May 2025 10:34 AM
Re: No connection
@Charlotte-Cox
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
