Discussion topic: No connection
Message posted on 22 Apr 2025 04:43 PM
No connection
4th time today it's gone off
ehats the issue?
Message posted on 22 Apr 2025 04:52 PM
Re: No connection
@13LJB
If you haven’t done it already use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
