Discussion topic: No connection
This message was authored by: Anita-
No connection
I did restart router but cant get connection at all,internet not working on my tv or phone
Re: No connection
@Anita-
If you haven’t done it already use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
